Old July 15th, 2004, 02:49 PM   #9 (permalink)
DrB
DrB's Avatar
Originally Posted by Mark Davis
There are 3-4-5-6 way switches but no 7 way.
You can get 7 with a 5 way switch and a mini toggle dpdt switch.
Sure I could do that if I were not to occupy my two push/pull pots. (The first activating a resistor; the second the bridge in any positions.) I wanna get rid off the push/pull pots, and use 2 dual concentric 500/500K pots, and wire the resistor to the switch! ;) And there are no push/pull dual concentric pots no?
BTW any links to the 6 way switches, that could help a bit. Don't care much for the middle-only position that much.
Thanks
DrB is offline   Reply With Quote
