Old February 27th, 2009, 01:32 PM   #19 (permalink)
Robi
Well, yes, I'm only 17 :)
Thank you, I don't know what else I could say...
About the bridge hole, on the left side it's 18mm wide and on the right it's 16 or so, and it should be 20. I know that it's not straight, but it will be when I route it on size (I hope)... So, you see, I'm a bit irresponsible too..
I went to the guy that works with wood today and he cut my maple to be 20mm and 25mm thick for necks. (20mm + 5-7mm rosewood = 25-27mm, the other one is one piece maple). I hope I'll start building necks tomorrow (weekend!!!), but the only thing i can make is to route out the truss rod channel and cut out the shape. I don't have the truss rod nut (it was shipped a month ago from stewmac but still hasn't arrived) so I wont be able to put truss rod into channels. (well, I could but this is the first time that I'm putting nut on the heel so I would like to do all the possible testing before gluing fretboard/skunk stripe)
Once again, sorry if my English is a bit weird
Robi is offline   Reply With Quote
