Look for Snapshot tool
Basically you open it in acrobat reader, select Tools, Select and Zoom, Snapshot tool.
Then Select an area to print with the snapshot tool. (Use the dimensioning lines so you create areas to line up to on each the separate sheet.)
Once you've selected an area, select File, Print. It will bring up just the area you selected with the snapshot tool. Ensure you check page scaling = none.
When that page has printed, use the snapshot tool to select another chunk and print. Repeat until you have all the pages you need.
To get a body outline it was around 6 pages of 8.5 X 11 for me, with overlaps.
