So we go back and repeat the process, taking long even sweeps with the grinder so the lines (new corners) are parallel with the fretboard edge.
Again, there's no need to worry about slight wobbles ... we're removing the meat at this stage.
But it is good to check that both sides have the same amount removed.
And the other side.
Less than half a millimeter. Close enough.
Another pass on each side.
