Then the center piece (there's five 12mm pieces) is glued to one side.
And then the whole shebang is glued and clamped together (forgot to turn the flash off).
Then after an hour or two of swimming at the local waterhole waiting for glue to set ... it got dealt with by a sander and a planer.
Where fingerboard will go once the truss rod is plugged. I'm thinking I might do the fingerboard after the radius - and only have it about 1/8" thick.
Headstock looking back. The curves will be cleaned up when the neck and headstock is cut. No point cleaning them up when half of it is about to be removed.
