Old November 30th, 2008, 10:05 AM   #1 (permalink)
Lewins
Where do I solder my ground wire to?
Does it get soldered to the under side of the bridge pick up plate? If so is there a preferencial place on the plate for the wire to be soldered to?
Ive had a go and come across a couple of problems.
1. Soldering technique: I tried to solder the wire to the back of the plate and it holds but then when cool just comes off. The solder stays on the wire and comes cleanly off the plate.
Do I have to heat the plate a lot before adding the solder?
2. The wire comes through a hole drilled from the bridge cavity and when I put the bridge plate on the wire stops the plate from being flush with the guitar body.
Any help or advice would be greatly appreciated.
Thanks Guys
Lewins
Lewins is offline   Reply With Quote
