Jack,
How did you fix the holes that were slightly offcentre?
Here a picture showing the holes I drilled from the headstock into the truss rod channel. The top one is a 1/4 in hole drilled using a guide block in the jig. The second one was done more or less free hand. Both are a little off to the treble side. Looks fixable to me.
http://www.tdpri.com/forum/telecaste...tml#post865250
My headstock hole is dead on but my heel is slightly off. I drilled using a 3/16" bit, so maybe going to a 1/4" bit will solve the issue if there really is one.
Bill
