Old November 20th, 2008, 12:30 AM   #11 (permalink)
viking
Pics would be helpfull ....Maybe you need something else to play , if you are disappointed with it now , and should just rest from the project for a while?
There is no reason why it couldnt be made into a decent player.
Decide first if you want to use a different body. If the neck have std measurements , the neck pocket may solve the problem you have with your current body.If you dont have the tools to route the neck pocket of the body you use now , youll have to sand the neck instead. Only a small amount removed will make a difference , but could off course be a problem when using the neck with a different body.
With the problems you have with the body/paint , the best thing could be just finding a decent finished body...
viking is offline   Reply With Quote
