Originally Posted by jwj4856
I just completed building a tele style guitar and did use the min wax poly on the neck, and with great results also, I did put 8 coats on it with one first thing i the morning and one at night, used a very light sanding with 0000 grade steel wool between coats, then did one final coat and let set for 3 days without touching, I used a very very slight yellow tint in this and it did turn out great.
Just want to clarify.... Did you put the tint in the poly or did you apply the tint as a separate coat? If you applied it as a separate coat, just wondering applied it to the wood first, or after poly was applied. I've read a couple of different ways that this has been done, so I'm trying to confirm if the tint goes on the unfinished neck first or after poly. Thanks.
