Old November 17th, 2008, 10:24 AM   #4 (permalink)
rajprods
Originally Posted by chiro972 View Post
you're going to put poly over nitro? I'm no expert, but you should do some checking to make sure that isn't going to be a problem. I have used wipe on poly on unfinished necks with good results. Just follow the instructions on the can. It does take many coats to get the proper finish. Using extra fine steel wool in between coats is important for that silky smooth feel.
No, I was going to get an unfinished neck.
rajprods is offline   Reply With Quote
