Old November 17th, 2008, 10:12 AM   #3 (permalink)
chiro972
you're going to put poly over nitro? I'm no expert, but you should do some checking to make sure that isn't going to be a problem. I have used wipe on poly on unfinished necks with good results. Just follow the instructions on the can. It does take many coats to get the proper finish. Using extra fine steel wool in between coats is important for that silky smooth feel.
chiro972 is offline   Reply With Quote
