Old November 16th, 2008, 01:40 PM   #8 (permalink)
pchilson
pchilson's Avatar
I just came back from getting some new fuses. Amp works a charm.
When I bought the fellow said the reverb didn't work and it didn't but he indicated he had "fixed" it before. I did some testing but couldn't find a fault with it so my deductive mind told me to swap the cables around...duh, anyway the other part of the equation is the footswitch must be used to turn the reverb on and off as there is no switch on the control panel plus there is no led on the footswitch to give you the state of the reverb...Also the footswitch must be used to turn on/off the lead channel for the same reason, no control panel switch.
I have also deduced the 6L6s to be GE as they match several pics I found of GEs.
What other famous amps use 4 6L6s that might have a comparable circuit that I could get a schematic for and see if there are similarities.
Back to playing, this thing has a lovely sound.
pchilson is offline   Reply With Quote
