Old November 11th, 2008, 02:48 PM   #8 (permalink)
boris bubbanov
boris bubbanov's Avatar
Originally Posted by superbadj View Post
well since strings (depending on the size you use, and your tuning) can put upwards of 200 lbs of tension (pulling the tuners and bridge towards each other), with the stress focused on the neck and the neck-to-body joint, I'm thinking that reducing 7, 8, 10, 12 pounds of that pressure isn't going to cause any real problems with the neck, the joint, or anything else.
I'm not an engineer, nor do I play one in TV commercials, but I approve of this message.
When i listen
