Originally Posted by iim7v7im7
Most Polytone's are fused, did you check to see if its blown?
iim7v7im7, I had checked the fuse on the back. That was fine. You were probably referring to a fuse on the "inside" and I didn't pickup on it. The other day an electrician friend of mine said "Take another look inside. There might be another fused tuck away in there."
Removed the back again and sure enough, there it was! had to move some insulation but tucked down at the bottom was another fuse in all its blown glory!
69 cent fix!
