Old September 26th, 2008, 06:21 PM   #7 (permalink)
spankdplank
spankdplank's Avatar
I'm sure I will get flamed for this, but here goes. If you like your existing bridge saddles, set up your three saddles to intonate as close as you can get, then get a pair of pliers and gently bend the G side of the middle saddle back and the D side of the saddle forward a bit. The intonation screw will bend slightly, but it can be bent back if needed. In most cases, this is all it takes to get a three saddle bridge to intonate properly, especially if your neck has a flatter radius like on the Highway 1's. Old school, but it works and it's free.
spankdplank is offline   Reply With Quote
