If you like the way your guitar sounds, and it already has brass saddles, compensated brass saddles is probably a good thing to do. It improves intonation.
If your guitar has steel saddles and you like the sound, beware that a change to brass may reduce the highs a bit.
How much depends on body wood, fretboard material, etc. Might not be a bad thing, depending on other factors.
