This is the fit after a bit of work..
Now on to the bridge…. I use a 48” rule to indicate the path of the strings, this way there are no surprises when I string ‘er up.. It lines up perfectly with the neck and the string-through holes..
run the mounting screws in and here it is at this stage..
rk
