Old September 21st, 2008, 08:18 PM   #126 (permalink)
Ronkirn
VENDOR
Ronkirn's Avatar
Moving right along..... today was to be the finale... but when I opened the box "o parts, I see the wrong pots.... but I did get close....
installing the Fralin P 90's couldn't be easier.... a bit of firm foam beneath, and run in the two mounting screws..
Once that’s done.. I address the neck pocket…. I always make ‘em tight, so each has to be hand fit at this stage. I begin by removing the lacquer buildup along the edges with a small sanding block.
once that’s done… I shape the corners for a tight fit…. This is before…
I Dremel it into submission..
RK
www.ronkirn.com
