Originally Posted by scubadoo
I've heard bad things about those, aren't they just feeler guages with teeth cut in? Apparently they wear out pretty quick and 'Norman' doesn't refund. How have you found them? They're not much cheaper than the files are they?
I can assure you they're not simply feeler guages. You can see they've been machined semi-by hand. As to durability, I admit I've only done a handful of nuts since I got them. I did get one of the stewmac double sided files once, I believe a .012/.016, and the edge got a little chipped up with use. For the price of the Norman files, you get bass string sizes as well though.
