Old August 28th, 2008, 08:17 PM   #91 (permalink)
Ronkirn
VENDOR
Ronkirn's Avatar
Oh what the heck… OK…..
Once the line is traced all around the periphery, let it dry….. BUT…. Before I ever let the ink hit the lacquer. I wet sand the complete top being sure the edge is as smooth as a piece of drafting film. Any irregularities must be drop filled, allowed to dry a day or so, and scraped flush then wet sanded. The wet sanding provides a perfect surface for the ink.
Now, after it had dried .. about an hour… it’s scraper time.. Set the blade to cut a perfect edge.. and scrape…..
Using a scraper is really quite easy… the tools I made allow me to rotate them to adjust the “bite” of the blade so I can pull it along with it taking a nice smooth cut. Some will bite and chatter along… that’s just more work.
IF you’re going to do this… make you up a test board with binding…. The pen trick, and scraping binding in general aren’t difficult, but there is a learning curve, once you “get the hang” of it, it’s like riding a bike… you can fall on you a** anytime…
Here are a few shots of the finished line…
Ron Kirn
"Life is not about waiting for the storms to pass...it's about learning how to dance in the rain."
"The Constitution only gives people the right to pursue happiness. You have to catch it yourself ." BENJAMIN FRANKLIN.
www.ronkirn.com
