- Higher heat-less hang time
- Clean tip (make sure you have a wet sponge to wipe it on)
- Clean solder surfaces (get yourself a little wire brush and clean the leads. SCRAPE the back of pots with a small screwdriver or knife blade.
Electronic solder has a flux core, and extra flux should not really be needed. However, when working on old connections, using a bit of flux or melting a little new solder into the old will help it to reflow.
Flux helps to boil-off impurities, it does not etch. Metals can build up an oxide layer over time that is inpenetrable by chemical means, making the wire brush treatment necessary on occasion.
John R. Frondelli
