With the neck placed in the pocket, I can use a straightedge to determine where the strings will fall, so I can see what the alignment of neck, string and bridge will be, and make any subtle adjustment necessary to have everything visually correct, which is far more important than things being technically correct, with the exception of that first string bridge… that’s gotta be right.
Just to be sure it’s all square relative to the presumed centerline
Now mark the location of the bridge’s mounting screws..
rk
"Life is not about waiting for the storms to pass...it's about learning how to dance in the rain."
"The Constitution only gives people the right to pursue happiness. You have to catch it yourself ." BENJAMIN FRANKLIN.
www.ronkirn.com
