Lance,
If you're still around, I just found your thread about the TF.
I've had my Time Factor for about a year now and just recently purchased the companion box, the Mod Factor. Put the two together and select a good guitar and amp(s) and there is an amazing array of super high quality tones you can get with just these two boxes. Just to work out some good wet effects combinations, I put a CVR together with a '72 SFVR. I input the guitar into the Mod Factor, then output to the Time Factor, then dual output into the ABY and split the signal to the two amp inputs. I run both amps with a light amount of background reverb and then work through some of the various effects combinations, a common one I keep coming back to is a modified Chorus with a modified Delay. These two Eventide boxes have eliminated a ton of individual pedals for me and I will now reintroduce this improved wet side, to my dry side amp setup with my front end two distortion pedals I use. I'm really pleased that Eventide brought this subset of the Harmonizer out so we can exploit it.
By the way, the CVR was a little too aggressive for my tastes, so I changed the 1st preamp tubes per recommendation on the Fender forum to GE five star 5751's and the PI to a balanced 12AT7 and it sounds just right.
played this combination for the last two days... if you've been thinking about the TF or MF, they are at the top of class.
