Old July 6th, 2008, 09:45 PM   #47 (permalink)
Ronkirn
VENDOR
Ronkirn's Avatar
I now give it a good sanding with 320…. This is to insure adhesion between the lacquer and the sealer.
And it’s time to begin… First I give the whole body a coat of clear lacquer… then begin with the edge by shooting a dark coat. Being careful to direct the overspray away from the center of the body..
I have seen many get carried away, trying to get full coverage with the first coat….not good… it’s a sure way to develop runs.. Runs + Transparent colored lacquer = major problem… take it slow and easy…. Adding additional color only after the last coat has “flashed”
And finally…
Every few coats of color, I will give the whole surface a coat of clear…. What this does is melt any overspray into the clear giving a gradual transition from the center yellow, to the dark edge. If you notice most ‘bursts have a very abrupt transition, giving them a “mechanical” appearance, the method I use makes for a very gradual flow from one shade to the next..
Ron Kirn
www.ronkirn.com
