Ok so I have a coat of sealer on ‘er.. I keep applying coats until I have a completely sealed surface…. I watch the light’s reflection as I spray watching for small points where the coat doesn’t cover minute grain irregularities…. If a few show… I’ll touch them with a needle to release any trapped air while the coat is very wet…
Once I see complete coverage, I allow it to dry thoroughly. By thoroughly I mean is has to be able to “powder” when sanded. Many sealers will feel qute dry after a few hours, but try to sand it and it “loads up”. This means the particles of the finish removed are still sticky enough to bind together, leaving “globs: of finish stuck in the sandpaper. Imagine sanding old chewing gum… it just does not work….
So sanded….. it’s ready for the color…..
Ron Kirn
