Old July 6th, 2008, 01:33 PM   #4 (permalink)
ehawley
The anchor....
The anchor is very simple! It is cut with a 120 degree cutter.
First you turn it to the diameter you want. I turn mine to .360 dia. Tap it, and hold it in a collet block...
Set the 120 cutter on center and cut away!!
Turn the block 90 degrees and cut again. You end up with an anchor that looks like this...
Mounting on the rod...
ehawley is offline   Reply With Quote
