Now, you can see I have already marked the reference lined for the round over, so using the rounded sanding block, repeat the same process as used on the arm contour. First take it down to the first mark, at about 45 degrees to the surface.
Then follow up with a second cut at about 22 ˝ degrees… on both sides of the 45 degree bevel.
and finish up by sanding with a finer grade paper to produce the round over.
Ron Kirn
"Life is not about waiting for the storms to pass...it's about learning how to dance in the rain."
"The Constitution only gives people the right to pursue happiness. You have to catch it yourself ." BENJAMIN FRANKLIN.
www.ronkirn.com
