For the lower horn, I use a larger diameter sanding stick…. < Technical term…
and completed…
Now, I move on to the fun part…. I mark the body to give me some idea where the round over should roll into the flat top pf the body…
and using a sanding block, I work down to the line…. Now this may look daunting… but it’s not….it goes quite fast and produces perfect results.
once the initial cut is made, I make a second…. This illustrates the 3 primary cuts made with a sanding block..
Ron Kirn
