Old June 30th, 2008, 01:02 AM   #19 (permalink)
RotelliCaster
RotelliCaster's Avatar
I went to GC and picked up 5 ft of the Planet Waves bulk cable. At $1.50 it's not a bargain to by a bunch of it at the store. I went to Radio Shack and pick up a couple of run of the mill 1/4" connectors. I came home, solder it together and test it against the other two cables.
The Planet Waves cable is by far the clearest and brightest cable of the bunch.
I can't find any specs for this cable to give me a reference point from the Canare cable. I wonder how the Mogami W2524 would compare.
Be for I did the test I carefully went through and checked the Homemade cable it metered out fine but I cut and re-soldered one end that looked questionable, the cable still sounds thick/dull.
If you can remember what that 25-30pF cable is Bill, I'd sure like to know.
" Trust me, I saw this in a cartoon and I'm pretty sure I can do it! "
http://www.myspace.com/bmwsteve
Guitar Photos
RotelliCaster is offline   Reply With Quote
