Old June 29th, 2008, 06:38 PM   #60 (permalink)
e-merlin
e-merlin's Avatar
Originally Posted by telbert twang View Post
the R/H side speakers (upper and lower) move much much less than L/H - any directional comments on that?
There´s 1 more question - the speakers jack - its connected into 16 ohms . Can i put the jack into 8 ohms instead, and what it would change ?
tt
I think I'd check to see if they are wired properly. They should all be 16 Ohm speakers and should be wired Series/Parallel. The wiring both sides should be the same.
I wouldn't run it off of the 8 Ohm jack since that will present the amp with an impedance mismatch. There is really no benefit to it, and it may make the amp sound bad. I did it with my 5150 and didn't like the results. Plus, it'll definitely wear the tubes out faster and may cause other problems with the amp.
If you need some help to see if the speakers are wired right, check out the Peavey Amp Forum. You can get there from this link:
http://www.peavey.com/support/forums/
You will need to register, but it's a valuable resource for Peavey owners or the "Peavey curious." Peavey's customer service guys check the forums several times a day and answer questions as they can, but only on weekdays.
'tone is in the underpants'
