Old June 29th, 2008, 12:39 PM   #4 (permalink)
mellecaster
mellecaster's Avatar
Originally Posted by blindsummit View Post
Thanks for that. I'm keen to give this a go, I'm pretty handy with hand tools so should be able to achieve it. How much work is there to do on the pickup hole? Is it a question of a few millimeters? Also can you describe a little more about elongating the string holes? If you've got a photo of the guitar with the bridge plate removed following the work, I'd really appreiciate it.
Thanks,
The small amount that needs to be removed from the pickup rout, can be easily done w/ a Dremel or Rotary tool w/ a small drum sander..or a small curved scoop hand chisel...I'm sorry that I don't have a Photo w/ the Bridge plate removed, and the Guitar is now in Germany...but it's just a matter of chamfering the 6 holes rearward in the body, to line up w/ the 6 holes in the plate, to make string installation easy...Hope that Helps.
I have never owned an Ipod or Blackberry..and doubt that I ever will......
