Brushing lacquer questions
I have ready access to Deft at Lowes and I'm wondering if anyone shoots it? I beleive it says it's "brushing" lacquer. I've been using the spray cans which I don't like nearly as well as the reranch stuff but it so much cheaper I'd like to make it work. I'm thinking about getting a preval and spraying it. Is that ok?
Questions:
If you can spray it, how do you mix it? Do you mix it? Can you shoot it straight? Is 2:1 about right? Too thick? Is 1:1 too thin? and so on.
What kind of dyes/stains can you mix with it for color coats? Do you shoo them the same strength as clear coats? and so on.
Any info or tips are appreciated
