Old June 19th, 2008, 03:10 AM   #8 (permalink)
Silverface
Silverface's Avatar
"Thanks Allen, I had been advised to soak it well first, then scrape it off, only
when it was completely drenched. On one amp its getting to
the stage of breaking up on one edge, still holding firm at
present."
That's terrible advice, because then you have hazardous waste in your possession, and good luck disposing of it without a fee. And as soon as it's dry, it's friable.
As Charlie said, paint it. Use a high-build elastomeric acrylic. It'll stick, it's not expensive, and it is used commonly in the trade as an asbestos encapsulant.
Tape is a bad idea - because if it's ever sold and someone removes the tape without knowing what's under there, you could be liable. Far less of a chance of that with an elastomeric coating.
FWIW many houses built in the 60's have asbestos in the flooring...not the tiles, but the glue that holds them! Don't ever emove a tile floor without having it tested.
“No Chops – Great Tone” ©
