Originally Posted by jwells393
Use the templates you made to draw the inside curve of the filler strips on 1/4 in. MDF. Cut near the line and sand to the line constantly checking the fit on the guitar body. The 1/4 in. MDF will be easy to sand. When it's perfect you'll have a template to cut the filler strips with a pattern following bit.
Good idea Jack. I hadn’t thought about the MDF being easier to sand. But I’ve made the templates and I’m nicely making way now.
I trimmed the cutouts with the drum sander as much as I could.
Then switch to a little hand work.
And wound up with this.
The fits are pretty good. I’m happy. So I think I’ll glue ‘em up.
That’s probably enough for tonight.
