Old May 24th, 2008, 07:32 AM   #13 (permalink)
idoru
idoru's Avatar
To make a detent (as extrapolated from a soldering error by myself): take off the pot casing and make an indent with a hole punch where you want the detent to be. This will require hooking up a multimeter to find where in the travel of the pot the required value is, and finding the equivalent place on the pot casing.
Now, a 40 watt soldering iron will melt the plastic mechanism inside the pot if you hold it in place too long (heh), so all you need to do is use the multimeter to find your place again and heat the indent for long enough. Voila, a detent - one of my old pots now has 3!
Needless to say, practicing on old Squier pots is highly recommended before you attack anything of quality.
c-
idoru is offline   Reply With Quote
