Old May 17th, 2008, 10:46 PM   #24 (permalink)
beep.click
beep.click's Avatar
Originally Posted by johnporter View Post
The only time you know you need the reverse feature,is when you have already been zapped. This is rarely lethal,but if it was a leathal hit---too late!
Curious what your tech/electrician's offer for advice as to when to use this feature.
I used to play a 2-prong Pro Reverb all the time. After I got zapped a few times, I put a foam windscreen on the mic.
The reverse switch WOULD solve the lip-zap problem.
Another test I got in the habit of doing: hold the guitar by WOOD ONLY, and bring the string up to the mic. If it was ready to zap, you'd hear a sizzling crackle, even before the strings actually touched the metal.
Recently, I got a Hum-X for ground loop hum issues. Not sure how this thing works; can't find a real explanation anywhere. Somewhere I got it in my head that it's an electronic form of ground lift. Don't know if that would help with shocks or not...
beep.click is offline   Reply With Quote
