Old May 16th, 2008, 01:00 PM   #12 (permalink)
Colt W. Knight
I gotta say Shubb capo as well. Those Kysers apply to much string pressure and go sharp. On acoustics using 13s, there not always strong enough to capo to proper pitch up the neck. Plus, the Kyser is prone to loose spring tension, and the one I have the strings actually wore out the rubber pad on the 6th and 5th string. Now when I use it I have to apply extra pressure to get it to clamp tight enough. I do not like Kyser Capos. Shubbs are great. When your not using them, you can simply slide them onto the nut where they are out of the way.
