Old May 16th, 2008, 04:56 AM   #2 (permalink)
jwells393
jwells393's Avatar
It shouldn't be loose. The cover is held on by three little bent tabs on the bottom of the pickup. The easiest was to correct it is to loosen the strings and remove the pickguard and pickup together. Once you get to the underside of the pickup you probably find that you can just bend a couple of the tabs and tighten it up.
