Old May 15th, 2008, 05:09 PM   #9 (permalink)
timmer
timmer's Avatar
Originally Posted by newtwanger View Post
If you look at your picture you can see the Bardens holes are wider spaced than those on your body (look in the low E string hole), and it's redirecting the E and A strings a tiny bit. Mine was aligned the other way that moved the B and E strings.
Actually, every string is centered in it's respective hole and I have a higher-res photo where you can see this. This E-type Nash was custom ordered to use the Barden bridge and can be seen here on his site (first one).
Here's a larger image:
"Choose silence of all virtues, for by it you hear other men's imperfections, and conceal your own."
George Bernard Shaw
timmer is offline   Reply With Quote
