Old May 15th, 2008, 03:30 PM   #18 (permalink)
telesavant
Originally Posted by lmcgillet View Post
telesavant, I am already dreaming of the drilling through the center of a screw... Wifey can't follow the things I talk about sleeping :::)))
Let me guess: I have to screw it into a hard wooden block to have that block fixed on the workbench while I drill the hole; only method I can think of without damaging the screw?!?
Flat Rat: Good luck again - I am convinced the ashtray will satisfy you!
Greetings -
Luther
Hello Luther!! Use a good machinists vice w/a "V" groove (this won't damage the screw), insert screw flush with the top of vice (Phillips head, 10-32, will self center a 3/32 drill), use brass!! Get a drill press, and the drill press table must be perfectly square. Now get a $#!tload of screws.....you'll need 'em. I do this on a machinists lathe, but a drill press will work....go slow, and use some type of cutting oil....WD-40 works good on brass.
If you plan on using a hand drill.........you better let me do it!!!!...Have fun!!
telesavant is offline   Reply With Quote
