Old May 15th, 2008, 03:08 PM   #11 (permalink)
John Thigpen
When I first read this, I thought it was in essence a two channel clean boost, but apparently there is no actual boost circuit, so the unit can only subtract gain and not add it. An interesting variation would be to add a boost circuit that could both reduce or add volume. You could use such a circuit for the rhythm/lead switch as described, or use it to switch betwen humbucker and single coil guitars (put two inputs in it while you're at it!).
John
John Thigpen is offline   Reply With Quote
