Old May 15th, 2008, 12:53 PM   #94 (permalink)
FenderGuy53
Originally Posted by Rob TeleMan View Post
Just wondering about solid state amps for Teles. I'm looking for a clean, sparkly sound. (I rarely use overdrive) I like the sound of tube amps, but I rarely play loud enough to get the desired effect, plus they're often too heavy & bulky. 30 watts would probably be fine. Not sure if I need a 12" speaker to get a little more warmth. Thanks!
It's not a solid-state, but it's the best bang for the buck, and it's a Fender. Check out the new Fender Super Champ XD for under $300. It's a 15-watt Class A/B, 6V6 output, tube amp with a clean channel voiced to a Fender Blackface and second channel with 16, mostly Fender models: Tweed (3), Blackface (3), British (3), Hot Rod (3), Metalhead (2), Jassmaster (1) and Acoustasonic (1). It's very portable (24 pounds), very loud and very toneworthy.
The only Fender solid states that I would consider would be the Princeton Chorus (60-watts, 2x10), which is not longer made, and the new Frontman 212R (100-watts, 2x12). Either can be had for under $300.
FenderGuy53 is offline   Reply With Quote
