Old May 14th, 2008, 10:04 PM   #4 (permalink)
jh45gun
The Kustom head has a line out and the 2x10 cab sounds good in fact it is rated pretty high in the watts dept 400 program 800 peak though I know they rate them generous LOL. I pushed it with my Traynor bass head that I use for guitar and it will take a powerful head and crank well so the cab is not an issue with the right head. The Kustom III head works fine just that since it is 4 ohm head it looses some power with this cab since the cab is an 8 ohm one. Still all in all it sounds a heck of a lot better than that Bassman did. This set up by its self for a small room gig would work and since it has a line out it would be fine for larger ones going through a PA. I am not disatisfied with this set up the 2x10 cab and the head as far as sound goes. Down the line I may pick up a 4 ohm 15 maybe for the Kustom head. I only traded it in the first place to get a more compact amp since I do not even play bass but have to haul the stuff for who ever does. The 2x10 cab is not that large so I guess it will suffice fine.
jh45gun is offline   Reply With Quote
