If you are not going to utilize that tone pot, just throw in a SPST switch in that position to take that two-wire function to ground to cut a coil. IF you want to have the tone control, a push/pull pot will cut the coil or take the pickup to parallel humbucking (which is very similar sonically to the single coil but is humbucking) and still can be used as a tone control.
