Check this diag.
http://www.seymourduncan.com/support...tic=1h_1v_1sas
Your tone pot is the "spin a split" pot. The red and white wires are often soldered together to have a full humbucker mode, that's what you'll see on many diags, converting to the split mode should be straightforward if your humbucker has these two single coils wires. I guess that your wiring will look like that diagram below but instead of the red/white taped together, you'll send them to your tone-split a split pot (which is not shown on the H-S-S diag)
http://www.seymourduncan.com/support...vol_1tone_5way
