Old May 14th, 2008, 11:40 AM   #15 (permalink)
Scott S
Scott S's Avatar
Originally Posted by giogolf View Post
I forgot to mention my version of the 5e3 is a 35 watt Lil Dawg d'Lux that Jim built for me. So some of the speakers above maybe under powered. I probably need something rated at 50W or higher.
Jeez, yeah that's important. You should probably just refer to it as a "Li'l Dawg" from here on out to avoid confusion...
This might help -- I have a 10W homebrew amp with no tone control. Its response is fairly flat, so most people would consider its sound to be a little dark and middy, like a tweed Champ. It's a great weed-out amp for speakers that aren't at least somewhat bright-sounding. A Weber Blue Pup (which are supposed to be bright and chimy) flunked the test, but the Jensen Neo 10" sounds very clear and tight, and I didn't even need to use my bright swtich. I would imagine the Neo 12" would respond similarly.
- Scott
PS The 10" Neo is rated by Jensen at 100W, but since the Weber version is rated at 75W, that's probably more realistic.
