updated my pedal board:
swapped out the launch pad for the boosta grade. the launch pad does more but i don't need the extra features. boosta grande is way quieter! i couldn't believe it!
swapped out the stock sd1 for the keeley mod version. my take on it is that the keeley sounds a little better but has way more range and overdrive! i guess there's only so much you can do to a sd 1 becasue it sounds great stock!
swapped out the boss tu-2 for the korg pitchblack. the korg is true bypass and has nice bright big screen. the pitchblack is plastic were as the boss is metal casing, so the pitchblack would be better off on a pedal board were a boss tu-2 can take a beaten.
