What kind of gigs are you playing? I would think that no matter what situation on stage you have, a 2 X 10 cab is not going to be enough to cover a room effectively.
Is there a way that you can run a line to the P.A. and use the 2-10's on stage as a monitor??
I guess if it were me I would get a single 15 inch 4 ohm cab and use that.
You are kind of in a bad situation. You could change the cab to 4 ohms but you are going to lose volume so you basically are in the same situation you are now.
éí 'aaníígÓÓ 'áhoot'é
Would you mind holding this bag while we go through the custom shop?????
Redd Volkaert is a Jedi Knight at one with the Force!!!
