Originally Posted by bowlfreshener
I have a Les Paul copy where the bridge is just maybe1/64"-1/32" off where it should be, just a fraction of an inch closer to the nut, so the wound strings are just a couple cents off from being able to be be properly intonated because there is no more room left on the screw or bridge to loosen the saddle to where it should be.
We're not talking Les Paul copies with their limited range of intonation adjustment. Telecaster type bridges have a large range of adjustment. If you run out of adjustment you can put in a longer screw if you need to move closer to the neck. You can shorten or take out the spring if you need to move further from the neck.
