You might remember a few months ago when I posted here asking about the little RCA I found. I wired a jack to the mic input and a stereo speaker to the output. It worked! It was clean all the way up to maximum volume. I was hoping for a little growl, but oh well.
I'm a fair woodworker so I figgered, 'how hard can it be to build a box?' Well I found out.
I found a bunch of nasty gray old wood at work, then discovered it to be mahogany when planed! Using just the limited time and tools available at work I built this on my lunch hours:
Note the really sloppy finger joints. Best I could do with only a table saw to work with. I filled the many gaps with clear epoxy. For some reason the flash really shows all the flaws. It really doesn't look that bad in person.
Here's the back view. I bought an 8" Weber Blue Pup. I have not heard the amp with this speaker yet:
It now looks like this picture below. Since I made a slanted front for the controls I had to add wires onto the originals inside the amp to extend the controls out to the new front plate. Gawd I hope I labelled those wires right:
Note the grille cloth. I found it on ebay for $12. I wasn't really crazy about it, just bought it because it was cheapest. Turns out to match the overall look very well I think. This cloth is NOS from the estate of Elmo and Patsy (Grandma got run over by a reindeer).
I didn't do a very good job of getting it on straight, but then there is nothing straight or square in this whole project.
